evanrudefx Posted July 31, 2017 Share Posted July 31, 2017 Hi! What's up with the sculpt tool? When I touch the corner of a box it raises the whole edge. Why does this happen? Thanks Quote Link to comment Share on other sites More sharing options...
Noobini Posted August 2, 2017 Share Posted August 2, 2017 it's because the 'ray' of the brush is hitting a whole row of pts...so they get moved (just a guess)...if you move your brush to up top, do the same to the corner then the ray looking down would affect a whole column vertically...it doesn't have to be at the corners...try in the middle...same thing, a whole column would be moved... Work around ? simply go into Brush tab, make Brush Angle non-zero 1 Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted August 2, 2017 Author Share Posted August 2, 2017 Thanks mate, I will give this a shot!!! Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted August 3, 2017 Author Share Posted August 3, 2017 That solved it!! thanks Quote Link to comment Share on other sites More sharing options...
