Accessing Global detail attributes through Python
atron
hi there,
I have a global attribute that i've made in a python node:
citySearcherDistanceTrav = geo.addAttrib(hou.attribType.Global, 'citySearcherDistanceTrav', '')
i've then set the attribute with some floats
totalDistance = self.stepSize * hou.frame() #speed * time = distance travelled
        dt = str(totalDistance)
        geo.setGlobalAttribValue('citySearcherDistanceTrav',dt) #see image 1
But i can't seem to access the values in the next node directly below.
I tried find global attrib not sure how to access the data in a python node again.
A
3 hours ago, Atom said:
The Copy node throws away attributes by default. Go to the Attributes tab of the Copy and add your attribute name to the list for downstream forwarding.
Hi Atom,
I can only see copy local variables which is checked. And then the standard topoint,toprimitive,to vertex , set ,mult, add and subtract table.
What list do i add the variable to.
