pasto Posted August 2, 2017 Share Posted August 2, 2017 Hello, I am making points appear in a scene with an inverted delete (based on color) and I would like to store this appearance time. Is there any way of doing this ? I guess I could use some kind of trigger in CHOP but I don't know where to 'send' it from chops in order to create a new attribute. I tried in vop with age but I guess it is related to particles age attribute only, not to simple sop deleting action. Many thanx. J Quote Link to comment Share on other sites More sharing options...
Doum Posted August 3, 2017 Share Posted August 3, 2017 Try with solver in SOP. and in a point wrangle or a vop create an attribute and add @timeInc (which is the frame/FPS) when your point get the right color. Quote Link to comment Share on other sites More sharing options...
mart1jn Posted August 3, 2017 Share Posted August 3, 2017 The expression you use in the delete-node basically calculates the birth-frame. You might be able to calculate the age by subtracting that from the current time. Quote Link to comment Share on other sites More sharing options...
pasto Posted August 3, 2017 Author Share Posted August 3, 2017 thx a lot Dominik and Martjin, So is there a vex function that returns the 'point existing' information ? Martin the expression in the delete is just something like @Cd.b < 0.1, is there anything returning the time of a delete action ? I just need the points birth frame to trigger some other stuff. Sorry if it is a bit confused. Many thanx. J Quote Link to comment Share on other sites More sharing options...
mart1jn Posted August 3, 2017 Share Posted August 3, 2017 My excuses, my solution was not practical at all. A solver is probably the best solution. I've added a simple example that makes the attribute life. life+solver.hiplc 1 Quote Link to comment Share on other sites More sharing options...
pasto Posted August 7, 2017 Author Share Posted August 7, 2017 thx a lot Martijin, I'll check it out. Quote Link to comment Share on other sites More sharing options...
pasto Posted August 7, 2017 Author Share Posted August 7, 2017 Very Nice Martjin, thanx a lot, But the time information comes only from the hit time attribute generated by the pop collision, cleverly transferred to stamp or any other way of applying it. I wish I could 'get' the time info of any point appearance, not just particles. I guess I can't avoid Chops… Many thanx anyway, nice file. Quote Link to comment Share on other sites More sharing options...
trzanko Posted August 13, 2017 Share Posted August 13, 2017 use a sop solver to accumulate an attribute over time, it's not just age or time it comes in handy for a lot of things like rotating particles based on how far it's traveled Quote Link to comment Share on other sites More sharing options...
