ManHatTan Posted August 2, 2017 Share Posted August 2, 2017 (edited) Hi. I'm looking to replace modo as my main tool, but I'm running into walls, workflow-wise, when trying modeling in houdini (been following tuts etc). I get that poly modeling isn't houdini's strength, but being an experimenter and a tinkerer I really like what I would be able to do in houdini down the line and I'm prepared to put some time into it. My question is, can I create my own modeling tools in houdini, basically? For example, the bridge tool in houdini: select one polygon, activate tool, select second polygon, press enter, adjust. It's just very clunky, following this 1, 2, 3 step every time you want to bridge. In Houdini, with or without python scripting, can I make a tool that takes two polygons (or polygon islands) and creates an adjustable bridge between them in one click/keypress, for example? tl;dr: Can I create my own modeling tools in houdini? Thanks! edit: I don't mean from scratch, of course, more "can I make the existing tools behave differently?". Edited August 2, 2017 by ManHatTan Quote Link to comment Share on other sites More sharing options...
mart1jn Posted August 3, 2017 Share Posted August 3, 2017 I'm not very experienced in Houdini myself, but I can tell you how I would approach something like this. As a relative beginner, I have no idea how to make interactive viewport tools (like the polybrigde tool). But I do understand what it produces, namely one polybridge node with the source group and destination group already filled in. So I would have a look at how to group the source and destination polygroups. Possible options are a group node, a partition node, a delete node and/or a wrangle node. That all depends on what the input geometry might look like. Possibly loop through the geometry to make multiple source and destination groups. When I have figured out how to make those groups and applied them to the polybridge node, I'd make a digital asset of it. A digital asset is still a few clicks, but it might not need to have any polygons selected (saves a couple of clicks) and might do several bridge operations at once (saves a lot of clicks) Hope this helps Quote Link to comment Share on other sites More sharing options...
animatrix Posted August 3, 2017 Share Posted August 3, 2017 You can make your own modeling tools. Check out some examples here: http://orbolt.com/search/?q=animatrix+sop Quote Link to comment Share on other sites More sharing options...
