Connectivity, issue with alembic?
So I noticed that some of the geometry that I import from alembic has some issues. I mean everything imports well but when I want to just explode the object on different geometry elements it does not work. When I use connectivity on my alembic file I get just one single class atriib for the whole thing.
Here is the example:
connectivity.zip
look at your geometry spreadsheet also if you middle click you will see that you have one primitive. You have to add a Convert Node (polygons) after you unpack.
Edited by Sepu
