lavitz01 Posted August 17, 2017 Share Posted August 17, 2017 how do i make a flip sim liquid thinner? Quote Link to comment Share on other sites More sharing options...
Atom Posted August 17, 2017 Share Posted August 17, 2017 (edited) If you are referring to surfacing, try setting Influence Scale closer to Droplet Scale on the particlefluidsurface1 node in the fluid import node. The default of 3.0 makes fluid a bit thick IMHO. Make sure to read the tool tip, however. Influence Scale must always be larger than Droplet Scale. But you can get them closer than the default. Edited August 17, 2017 by Atom Quote Link to comment Share on other sites More sharing options...
