attribute name either not used or unrecognized
Atom
Hi All,
I have a set of points I am trying to connect with connectadjacentpieces. The node does connect some points, but I want to connect all points. The node has an error..."attribute name either not used or unrecognized". I assume I need to name something, but I just have points.
What does this error mean and how do I fix it?
  • 3 years later...
Hello,
Don't know if you still need this but for anyone else,
You should unpack geometry before trying to use that node. It can't find the "name" attribute because the geometry is still packed.
Hope that helped.
