Understanding Vex documentation
Hey,
I have been reading the houdini manual section on vex. I must be understanding the documentation incorrectly. For instance, here is the syntax in the documentation for "if" statement:
if (conditionstatement_if_true [else statement_if_false
What I don't understand is that syntax doesn't work.
If I write: if (@id < 60) force.y = 20 [else force.y = -20];
that does't actually work. I must write this:
if (@id < 60) force.y = 20;
else (force.y = -10);
Writing it that way works. Why would it show the syntax the other way if it doesn't work?
Thanks
This is at the top of the help page.
As in C and many other languages, you can enclose multiple statements inside curly braces to act as a block.
The bracket just means the statement is optional.
A lot of languages are based upon the syntax found in the original C programming language book. Pick it up at a used book store or online.
https://en.wikipedia.org/wiki/The_C_Programming_Language
Meanwhile, report the documentation confusion to support@sidefx.com.
  • Like 2
