avak Posted August 29, 2017 Share Posted August 29, 2017 (edited) Hi Friends, May I ask if you know how to achieve this kind of look that liquids are so soft and blobby shapes, please point me to a good direction, Thanks Edited August 29, 2017 by avak Quote Link to comment Share on other sites More sharing options...
garf Posted August 29, 2017 Share Posted August 29, 2017 How about just doing a sim as you normally would be then using the VDB tools to sculpt it / smooth it into a less defined shape? Quote Link to comment Share on other sites More sharing options...
avak Posted August 29, 2017 Author Share Posted August 29, 2017 8 hours ago, garf said: How about just doing a sim as you normally would be then using the VDB tools to sculpt it / smooth it into a less defined shape? Thanks, to achieve a still image the method you mentioned will work, but for a sequence, if we could tell vdb to look at a specific shape and it tries to get to that shape at all frames it would be a solution. Does it make sense? Quote Link to comment Share on other sites More sharing options...
