Python beginner - executing from external python script
gweiss
learning python, I'm trying to do a simple test of creating a custom shelf tool that calls a function from a file to create a sphere
I copy the create sphere shelf button script:
import toolutils
import soptoolutils
rad = 0.5
kwargs['bbox'] = hou.BoundingBox(-rad, -rad, -rad, rad, rad, rad)
sphere = soptoolutils.genericTool(kwargs, 'sphere')
sphere.parm("type").set("polymesh")
sphere.parm("radx").set(rad)
sphere.parm("rady").set(rad)
sphere.parm("radz").set(rad)
I save a .py file with a new function and paste the script with a small change of - rad = 1
so I have a saved file called spherebig.py that looks like that
import hou
import toolutils
import soptoolutils
def createBigSphere():
    rad = 1
in my new shelf tool I enter this on the script tab:
import spherebig
spherebig.createBigSphere()
and when I press the button I get this error:
NameError: global name 'kwargs' is not defined
am I doing something wrong or is there a different way to create objects this way?
Thanks
gweiss
Well, you have not passed in kwargs. I don't know this for certain, but when a button script is run by Houdini it is probably passing that in, behind the scenes. (i.e. tool shelf code is running inside of some sandbox that has been given kwargs). When you externalize that process you now have to become the provider of kwargs. Maybe read up a bit on python kwargs?
Add an argument to the function. It can be any name, use kwargs as convention:
def createBigSphere(kwargs):
    pass
Pass the kwargs when call it from shelf.
import spherebig
spherebig.createBigSphere(kwargs)
kwargs is a dictionary populated with useful contextual stuff and available in most places where you use Python in Houdini. Contents are varying, so I usually print kwargs to see what's available to use. Shelf script kwargs contain details about how the user activated the script.
I think Houdini kwargs is different from common Python **kwargs syntax and idiom, but they still share properties.
