craigls Posted September 4, 2017 Share Posted September 4, 2017 Hi, Can someone help, and explain why after translating a cube up in sops, on the geometry node to postion a box on top of another box. then making it a RBD object. then simply add a deactivate object from the shelf tools, why my pivot and object change position when I jump into dops. Perhaps Im missing something silly here, anyone help please? thanks in advance. Quote Link to comment Share on other sites More sharing options...
RoaringDog Posted October 17, 2017 Share Posted October 17, 2017 (edited) http://www.sidefx.com/docs/houdini/dyno/keyframe "When the object is inactive (Active = 0), keyframe the RBD Keyframe Active node’s Position and Rotation parameters to move and rotate the object manually, not the object-level transforms." REFERENCE IS KING! Edited October 17, 2017 by RoaringDog Quote Link to comment Share on other sites More sharing options...
violalyu Posted October 20, 2017 Share Posted October 20, 2017 Hi Craig, Maybe check on "use object transform" on your rbd object in you dop? Quote Link to comment Share on other sites More sharing options...
