lavitz01 Posted September 16, 2017 Share Posted September 16, 2017 i created a mandlebulb/mandlebrot and i want to animate it with colors that change like left 30% green right 70% blue and it changes over time. I do not know how to accomplish this. Please help. mandlebrot_016.hip Quote Link to comment Share on other sites More sharing options...
mestela Posted September 17, 2017 Share Posted September 17, 2017 A few different things you could try; in 2d you can store the number of iterations of the fractal function, and use that to drive a ramp. In 3d you're generating the surface where every voxel has the same value, so that wouldn't work (or there might be, but I haven't hit up any fractal forums). Instead I went 2 lazy methods. One is to just use the position relative to the bounding box of the shape. The other is to measure the curvature. In both cases I use that to drive a ramp, and in a third wrangle I use a mix of both. mandlebrot_016_col_me.hip Quote Link to comment Share on other sites More sharing options...
