Polyextrude with falloff object
JulesGuerin
Hi, i'm trying to have my polyextrude distance controled by a falloff object. The falloff object have a red color node and I've followed Rohan Dalvi's tutorial about attributes and polyextrude: https://vimeo.com/149640497
I'm kind of stucked here, the red color is correctly to tranfered to the extruded object, I'm setting an attribute create named "x" just before the polyextrude node and put x in the distance scale but it doesn't work.
This must be a newbie mistake but i would very appreciate if someone could point me to the solution!
extrude_falloff.hipncFetching info...
