Hot - The Houdini Ocean Toolkit
eloop
Nice image Mike. Out of interest did you use the SOP or the VEX ?
lisux: foam will get easier to produce when I get the minimal eigenvalue code working via vex. Hopefully in the next few weeks if I get the time to work on it.
-Drew
20848[/snapback]
Thanks eloop.
I'm installing visual stuido 2003 in order to compile a version for the aprentice version.
Is the version that i use and at the moment there aren't any HOT version compiled for it.
Thanks eloop.
20865[/snapback]
You should be able to still use the VEX DSOs without a problem, lisux. The SOP does nothing more than the VEX code on the Wiki run against a grid.
