How to use a point attribute for Distance Scale in Poly Extrude?
magneto
I saw a tutorial by Rohan which uses Point SOP to post displace the extruded points but I am looking for a way to directly use a point attribute to drive my poly extrude. Is it possible or is poly extrude only limited to prim attributes when it comes to using attributes to override parameters?
Yeah it seems like polyextrude only takes prim attributes. If you want to extrude individual points on a mesh then a displacement is the way to go. I've thrown together a couple of quick examples, including one where I have separated out the prims with a fuse sop set to unique and one where I've ran a polyextrude in Individual components mode and then displaced the points with a random function in a wrangle. Not sure if it's any help but maybe it'll give you some ideas?
polyextrude_v1.hipnc
