nvlnvl Posted October 7, 2017 Share Posted October 7, 2017 I'm more or less brand new to Houdini and have been trying a basic cloth sim but have had some problems. As you can see in the image both in and on the folds I'm getting some strange shading artifacts like the smooth shading is breaking down, almost as if the direction of the shading is being flipped on some faces. It's a tool shelf grid for the cloth object and static torus for the collision object. I feel like I must be missing something really basic but have googled, read the docs and just hit a wall with how to fix this. If anyone could shed some light on why this might be happening it would be really helpful, I've played with the settings a lot and tried normal and facet nodes (though I may of been putting those in the wrong place!). Quote Link to comment Share on other sites More sharing options...
fencer Posted October 7, 2017 Share Posted October 7, 2017 Add normal node. Quote Link to comment Share on other sites More sharing options...
nvlnvl Posted October 7, 2017 Author Share Posted October 7, 2017 Hey thanks very much! I had tried a normal node with little success, but tried again adding it after the dopimport ....then added a smooth and another normal node and was able to remove the artifacts. Obviously there's a loss of detail and some extremely subtle remnants of the problem, but it does look and render clean. Cheers again. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted October 7, 2017 Share Posted October 7, 2017 Display Options / Geometry / Cusp Angle = 360 Quote Link to comment Share on other sites More sharing options...
nvlnvl Posted October 10, 2017 Author Share Posted October 10, 2017 Hadn't even thought to look there in display options, cheers marty! Quote Link to comment Share on other sites More sharing options...
