going crazy with advceting points (vdbadvect)
tfreitag
hey,
here I have file where I try to advecting with vdbadvect inside sopsolver. the points going crazy. if i raiseing the substep it getting better, but its way to slow...because i will advecting 90mio points. Maybe there some bad velocities or the resize container?
hipfile: https://we.tl/8OLaIq8Upx
any solution would be nice. thanks in advance. tom
The problem  seems to be that you are not keeping both sides equal. When you convertvdb for one side, make sure you match the settings on the other (i.e. Convert Fog to SDF). Also, turn off that vdbresample unless you plan on resampling the other side too.
It worked fine for me after that, no more exploding velocity.
  • Like 2
