Pelayo Posted October 11, 2017 Share Posted October 11, 2017 Good night, people: I'm a newbie with Houdini. I've tried lots of tutorials but, I'm still having problems with collisions. I made a simple setup, a growing fem ball inside a static collider, but, it interpenetrates the walls of the static object. I tried to get more substeps, to have more detail in collision guides, but I'm not sure what I'm doing wrong. I attach the file that I'm working on. Thanks! testme.hipnc Quote Link to comment Share on other sites More sharing options...
fencer Posted October 12, 2017 Share Posted October 12, 2017 Set "Local scaling" to "Use Local Feature Size" to have more accurate solidembed. In "box_object1" set "Division size" to 0.05 or less. Change substeps to default 4 and 2 for collision. 2 1 Quote Link to comment Share on other sites More sharing options...
Pelayo Posted October 12, 2017 Author Share Posted October 12, 2017 12 hours ago, fencer said: Set "Local scaling" to "Use Local Feature Size" to have more accurate solidembed. In "box_object1" set "Division size" to 0.05 or less. Change substeps to default 4 and 2 for collision. Thanks fencer, it worked in this setup but... when I tried to work with thin walls in the collider object, again... it overlap again. Tried to raise sphere divisions and lower "Division size" in box_object1 but didn't make too much difference. Quote Link to comment Share on other sites More sharing options...
fencer Posted October 12, 2017 Share Posted October 12, 2017 18 minutes ago, Pelayo said: Thanks fencer, it worked in this setup but... when I tried to work with thin walls in the collider object, again... it overlap again. Tried to raise sphere divisions and lower "Division size" in box_object1 but didn't make too much difference. Make a screenshot of the problem area, maybe I do not understand what do you mean. Quote Link to comment Share on other sites More sharing options...
Pelayo Posted October 13, 2017 Author Share Posted October 13, 2017 (edited) 12 hours ago, fencer said: Make a screenshot of the problem area, maybe I do not understand what do you mean. I tried your settings and that minimized the problem. But there's still some interpenetration of the sphere with the box. My idea was to finally do a thinner outer box, but when I try to do that, the inner sphere escapes from the box. Using the thick wall sphere starts to overlap box. If I try thinner walls: Edited October 13, 2017 by Pelayo Quote Link to comment Share on other sites More sharing options...
yglemarec Posted October 13, 2017 Share Posted October 13, 2017 (edited) Hello, by raising your sphere division, your sim is more accurate but i takes more time to compute... and sometimes, the result is still not perfect ... and it seems you are in this case. if i were you, i would keep your sim as it is , and after that, i would make some adjustements with sop point nodes to reduce overlapping. bellow 2 variations of the same method. have fun with your muffin ! ++ testme-sop adjustements-ok++.hipnc Edited October 13, 2017 by yglemarec 1 1 Quote Link to comment Share on other sites More sharing options...
Pelayo Posted October 14, 2017 Author Share Posted October 14, 2017 21 hours ago, yglemarec said: Hello, by raising your sphere division, your sim is more accurate but i takes more time to compute... and sometimes, the result is still not perfect ... and it seems you are in this case. if i were you, i would keep your sim as it is , and after that, i would make some adjustements with sop point nodes to reduce overlapping. bellow 2 variations of the same method. have fun with your muffin ! ++ testme-sop adjustements-ok++.hipnc Thanks for this solution. I always though that solvers where more accurate and I was doing some bad setup. 1 Quote Link to comment Share on other sites More sharing options...
