problem with flip
highdensity
Hi Nicolas
Are you using nested dielectrics here?
If so try reducing the ray tracing bias (Rendering/Shading) on the render node.  I've seen similar patterns appear when liquid intersects a thin glass wall when using nested dielectrics and that did the trick.
If not you could try
- increasing the refract and/or reflect limits (render out the image planes to see which if either is the issue).
-if that works but increases your render times by too much, switch at ray limit to - use direct lighting as background color.
Hope that helps in some way.
cheers
Nigel.
