Blend parameter doesn't work with point attributes?
antoniosouza3d
I'm trying to drive a BlendShapes' SOP blend parameter using a point attribute, @fade.
The @fade is a point attribute and have it's value animated.
But the blend parameter doesn't appear to read this animated values and keep showing 0 instead.
The question: the blend parameter doesn't work with point attributes?
I tried VEX and Hscript forms (@fade and $FADE). The second crashes.
