guache Posted October 23, 2017 Share Posted October 23, 2017 (edited) I have a COPS setup of ~25 nodes. I'm trying to comp a sequence of about 10,000 frames and I see a memory leak. Every frame adds about 20MB to used RAM. Given the length of the sequence, I keep running out of RAM. Is there a way around it, e.g. some kind of a COPS node that frees up memory or some other workaround? In Compositing Settings, I've already lowered the max comp resolution to the minimum I need, and the bit depth to the acceptable minimum (8-bit) but the leak is still here. Win 7 x64, Houdini 16 Edited October 23, 2017 by guache Quote Link to comment Share on other sites More sharing options...
lamer3d Posted October 29, 2017 Share Posted October 29, 2017 I've noticed that too. It doesn't free up memory, and over time completely fills it up so you have to restart. Quote Link to comment Share on other sites More sharing options...
