Rigid Object using Grains (styrofoam)
ParticleSkull
  • 11 months later...
On 23.10.2017 at 8:09 PM, ParticleSkull said:
hey guys, is there a way to make a granular solid to be very rigid? Not cloth like.
I have to simulate a detailed styrofoam breaking and it would be perfect if I could work with grains.
Thx,
Alvaro
Did you ever find a solution to this? I need to achieve similar result.
  • 2 weeks later...
May be the better approach to this task is to use packed rbd's with
Thx,
Alvaro
I think it will be very hard with grain solver, if not impossible. Probably the better way to do this is to use bullet solver & packed rbd's and mix of hard/glue constraints. So you can break them with some attribute or force when and where you need to.
