Rendering Pyro Passes Workflow [solved]
Hey,
I am looking for advice on a good workflow for rendering and compositing a pyro sim with both fire and smoke. I know that fire has no density, only smoke. So, I turned on two image planes, one for smoke_mask and one for fire_mask. What exactly do I do once I am inside nuke and what are the intended purposes for the fire and smoke masks? How are they to be used together?
Thanks,
Evan
edit: Do I need to render out fire and smoke separately or is one pass with both fire and smoke mask enough?
Edited by ejr32123
  On 10/29/2017 at 10:15 PM, fencer said:
They (fire/smoke mask) intended for masking :D Change color, intensity, other operations...
The main goal is independent control in each pass, this can be done by example above.
Expand
Ohhh, I see now. Thanks!
edit: I got it working now!!!!
Edited by ejr32123
