Vex_Question
Hi guys,
I'm a junior houdini artist, I'm studying vex now and it's very useful but quite difficult for me at the moment. I was wondering how to do the dot product of the same vector between two points in a geometry and then calculate the angle for every points of that.
I'm not sure if I have to use the neighbour vex function in the point wrangle and then use the foreach loop vex function to calculate the angle between the two neighbours points for every single point in the geometry. Or instead of the neighbour code I have to use the xyzdist vex function. I'm a little bit confuse at the moment.
I hope I have been clear enough.
Thank you so much!
Cheers!
