Dot Vector in Python ?
CinnamonMetal
#Like this
vector_one = hou.Vector3((1,0,0))
vector_two = hou.Vector3((1,0,0))
if vector_one.dot(vector_two) == 1:
	print 'match'
#Or like this
if hou.Vector3((1,0,0)).dot(hou.Vector3((1,0,0))) == 1:
	print 'match'
-b
  • Thanks 1
Correct me if I'm wrong, hou.Vector3 takes a tuple; I attempted using it without a tuple and it worked ?
I'm referencing your alternative code example. I don't want to use integer or float values for the vector I want to use a variable containing a tuple; unless you were already aware of that based on my original question ;)
I'm looping over each primitive; with that in mind, my goal is to take a vector3 tuple compare that with 1.0 whether the truncated value is equal to that of the full float value based on color, if based on color is anything of importance to begin with ? ;)
Im not entirely sure what you actually want to do but if you want to use the dot product method of the hou.Vector3 class, you are not doing it the right way.
In your code you are calling:
hou.Vector3(primColor).dot
This makes python return the method it self, not the value the function is supposed to return. If you print this you will get something that starts with "bound method..."
To make this work you also need to supply the dot method with a vector:
hou.Vector3(primColor).dot(rounded)
The first statement will always return True whereas the second will return any vaule between -1 and 1. Depending on the directions of the two vectors (primColor and rounded) you pass in.
Cheers
Bonsak
Edited by bonsak
I have three sets of floats or a tuple.  I'm going to take into consideration you're right; by right I mean I'm comparing a truncated tuple (Vector3) with the full value tuple (Vector3) otherwise made up of three float values (float,float,float) you get the idea ;)
Anyhow if they match, then the result should print "match" that isn't the case looping over primitives; rather I'm getting "no match" therefore, my problem may not be the Vector3 it may be the truncated tuple :unsure:
I think the problem is that you are not using the dot method the correct way.
You are using
"hou.Vector3(primColor).dot"
but you need to use
"hou.Vector3(primColor).dot(rounded)"
will never return the dot product. It will return the method it self as i wrote earlier.
-b
As a rule of thumb you never compare two different float values using ==.  Floating point arithmetic is not numerically precise, every operation performed on a float results in a "Floating-Point Error" (tiny imprecisions due to the nature of decimal representations on modern hardware).
If you want to know if your color and your rounded values are normalized and parallel(which seems to be the question your asking?) then the most straightforward way would be,
dot = hou.Vector3(primColor).dot(hou.Vector3(rounded))
tolerance = .000001
if dot >= 1.0-tolerance and dot <= 1.0+tolerance :
  print "match"
.  Houdini's Vectors types also have almostEquals functions which do similar tests for each element in the array.
  • Confused 1
I'm not sure what exactly your asking.
tolerance = 0.000001
This works in my interpreter, I get 1e-06.
What
does is check if dot is within 2*tolerance of 1.0.  It's the same as saying abs(dot-1.0) <= 2*tolerance.
So if tolerance was .001 on a number line it would look like,(not to scale)
        .9990   .9999    1.0     1.0010     1.0011
--------|-------x--------|--------|---------x1----
so x, being .9999, would be true as its greater then .9990 and less then 1.0010, but x1 would be false as its 1.0011 which is greater then 1.0010.
I'm getting an error within the function.  Does there appear anything wrong here ?
        if dot >= 1.0-tolerance and dot <=1.0+tolerance:
            print("match")
        else:
            print("no match")
Otherwise the error is; AttributeError: 'module' object has no attribute 'theLooper'; being the name of the function ?
Edited by CinnamonMetal
