Adding points to a groups selection in H16
The second one.
I select some points on a geometry (a head model in this case) and group them in a group sop, name the group and use that group to perform a soft transform. Then I find out I really need to add or change the points in the group to shape the geometry bit differently. It was easy to do in H15 but now . . . I have no idea how to do it.
Are you talking about the tilde "`" key thingy? if that is the case that still work to add or remove pts. Remember to select the grp node then in the view-port press enter then the tilde key, that will disconnect the connection upstream temporarily then add/remove pts, press enter to confirm your selection.
