houdini looses sop level material assignment
Does anyone else have a problem with SOP level material assignments randomly stopping displaying properly in the viewport?
This is happening across several computers, so I'm assuming its not a graphics card issue.
The image renders fine. Its just the viewport. Once the assignments are gone, I cant get them to display again. Everything just renders with a grey shader.
If anyone else has seen this, you know of any workarounds while I'm waiting on the bug feedback from SESI.
I experience the same viewport bugs in H16.5 as I did with H16.
I open the scene my viewport remains empty. (even though there are valid Display flags set)
I go up to /obj and then dive back in and the viewport refreshes and finally draws what it should have drawn on load.
