bobc4d Posted November 8, 2017 Share Posted November 8, 2017 (edited) I am new to Houdini coming from Cinema4D. I am trying to recreate a project done in C4D. it starts with a TEXT (font) object which is a spline (line) not a polygon as in Houdini, then use a C4D command called 'create outline' which copies and scales the spline. I've attached a pic of what I mean. The outer line is the original, the inner is the copy. is there a tool in Houdini which can do this? EDIT: is there a way to extract the line from the Houdini Font? Edited November 8, 2017 by bobc4d Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted November 8, 2017 Share Posted November 8, 2017 Try polyexpand. Quote Link to comment Share on other sites More sharing options...
bobc4d Posted November 8, 2017 Author Share Posted November 8, 2017 Thank you Konstantin, that did the trick and did exactly what I wanted. Quote Link to comment Share on other sites More sharing options...
