DOP, constraint SOP problem
Jamshid63
Hi everyone.
I was trying to make an effect of Breaking the Geo in mid-air.
So basically what i did in order to get that was, i used Velocity attribute inside Dop, SOP solver, to make the Geo breaks in mid air. but as the fractured pieces falls on the ground, the glue constraint impact still stays. And end up getting mannequin kinda effect.
HELP ME FIX THIS.
feel free to suggest different ways to achieve the same effect.
DOP_SOP_Constraint_issue.hipnc
hi jamshid,
you import your glue network from your geometry level using object merge which will not get update as per your sim..all you have to do is take your glue network from relationship node which is already present inside your sop solver
this relationship node take your glue network from dop net so get updated as per your sim...hope this will help thanks....
Edited by vineet
