DeeLan Posted November 19, 2017 Share Posted November 19, 2017 (edited) I need some suggestions on how to fracture an existing RBD object inside of a SOP Solver. The two solutions I've tried so far crash after a couple of fractures. All it is is a ball floating around and when ever CHOP network returns a value of 1, each piece of the ball splits into two smaller pieces. For those interested in how I'm currently doing it, I've got my RBD object plugged into a multi-solver, with the Rigid Solver in slot 0 and the SOP Solver in slot 1. Inside the SOP Solver there's a switch that reads some data from a CHOP network. If the result is not 1, then it just puts through the existing geo, if its 1 then it (tries to) fracture the object. My current solution is to unpack the object, scatter points and voronoi fracture the object, assemble the object, transfer all attributes except for name and id from the piece being fractured, and then give each piece a unique name. This kinda sorta works except for the fact that after a few fractures it just crashes. CPU and RAM usage are basically nothing, it just seems that I've done something wrong and Houdini doesn't like it. dancing_sphere_odforce_v1.hipnc Edit: This latest version is working a bit better, but still crashes a bunch dancing_sphere_odforce_v1_5.hipnc Edited November 24, 2017 by DeeLan Update Quote Link to comment Share on other sites More sharing options...
3dome Posted November 19, 2017 Share Posted November 19, 2017 (edited) works for me. was able to play the whole framerange without any trouble (H16.5). Edit: H16 does crash for me too Edited November 19, 2017 by 3dome Quote Link to comment Share on other sites More sharing options...
DeeLan Posted November 20, 2017 Author Share Posted November 20, 2017 That's really weird. I'm getting crashes in both. Do you have any suggestions for how to approach this differently? Quote Link to comment Share on other sites More sharing options...
3dome Posted November 22, 2017 Share Posted November 22, 2017 (edited) yup weired. just tried it again and now it did crash in 16.5 aswell anyway I had the idea of prefracturing it down to the max fractured level and using constraints to hold the pieces together... it made me crazy but I finally got a solution working. but I feel like I missed something that does the same thing waaaaaay easier dm_dancing_sphere.hipnc edit: might have a closer look at why your file aint working when I got time Edited November 22, 2017 by 3dome Quote Link to comment Share on other sites More sharing options...
DeeLan Posted November 24, 2017 Author Share Posted November 24, 2017 On 22/11/2017 at 11:37 PM, 3dome said: anyway I had the idea of prefracturing it down to the max fractured level and using constraints to hold the pieces together... it made me crazy but I finally got a solution working. but I feel like I missed something that does the same thing waaaaaay easier Yeah its not fun is it haha. But i guess for now its the method we're stuck with. Quote Link to comment Share on other sites More sharing options...
DeeLan Posted November 24, 2017 Author Share Posted November 24, 2017 @3dome I Believe that the fact that multiple fractures left us with ridiculous ngons is at least partly to blame for the crashes. I've reworked the sop solver a bit and added a dive node to make sure we always have tris. Its still crashing but its alot better than it was before. Funnily enough I've found that lowering the resolution of the sphere actually causes it to crash more often. dancing_sphere_odforce_v1_5.hipnc Quote Link to comment Share on other sites More sharing options...
Noobini Posted November 25, 2017 Share Posted November 25, 2017 (edited) i got it working right thru....so here's what I've done...bear in mind..I'm very inexperienced at this... 01) I looked at your sopsolver, dive in, dop_geometry, now you're creating PACKED geo to start off with and also breaking them as you go and then create more PACKED geos...and yet your Import Style....doesn't make sense to me....I stress...I don't know shit....but I simply do what makes sense to me so I changed Import Style to Fetch Packed Geo 02) I see you're doing attribtransfer , except for id and name...I guess name comes from the orig assemble and also the assemble in the for loop....so fine there...but I can't find where new ids come from...how does a new 'broken' piece get new id ? Dunno, so I enabled Add DOP Object Id Attribute (in dop_geometry node) It then works... For low res on the starting sphere, I think this is just a common problem with boolean/fracturing logic. If you boolean a simple box...incredibly low res...there's simply not enough geo for it to play with so it creates s*** geometry as a result leading to crashes. Edited November 25, 2017 by Noobini Quote Link to comment Share on other sites More sharing options...
DeeLan Posted December 9, 2017 Author Share Posted December 9, 2017 Hey thanks for your help I've got it working now even with lower res spheres Your note on the ID attribute sparked some thought. I had the wrangle set the ID to -1, as was suggested to me over on the Houdini Artists Facebook Page ( the logic being that doing so forces Bullet to calculate a new collision hull). But After reading your comment about the IDs i changed it to make the IDs equal to the point number, and now it works perfectly Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 9, 2017 Share Posted December 9, 2017 that's the advantage of being a noob...a noob has no advanced knowledge...so all he can rely on is 'common sense' Quote Link to comment Share on other sites More sharing options...
