avguy Posted November 20, 2017 Share Posted November 20, 2017 I was messing about with the new version of Houdini and the air incompressibility specifically. I'm dropping objects in a flip tank and I am getting cool reactions with bubbles forming and going to the surface - my question is now how do I mesh it? Is there a best practice? (Houdini novice here) If I use the default meshing I get the fluid and exterior splashes but not the air bubbles inside of the body of fluid. I tried to find info in the help doc but no success yet. Do I take the flip sim and create another second surface just for the internal bubbles? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
Rgoldade Posted November 20, 2017 Share Posted November 20, 2017 Hey! There is a new option in the Particle Fluid Surface node to help with this issue . Set the Method to "Spherical" and you should see a new toggle titled "Preserve Bubbles" show up. This should solve your problem. Hope that helps, Ryan 1 Quote Link to comment Share on other sites More sharing options...
avguy Posted November 22, 2017 Author Share Posted November 22, 2017 On 11/20/2017 at 4:38 PM, Rgoldade said: Hey! There is a new option in the Particle Fluid Surface node to help with this issue . Set the Method to "Spherical" and you should see a new toggle titled "Preserve Bubbles" show up. This should solve your problem. Hope that helps, Ryan ahh..can't believe i missed it (yes actually I can ) perfect. Thank you! Quote Link to comment Share on other sites More sharing options...
tamagochy Posted November 22, 2017 Share Posted November 22, 2017 In 16.5.268 there is no option for preserve bubbles( Quote Link to comment Share on other sites More sharing options...
