Detection of open and closed surfaces
starlighter
@Noobini Haha indeed! All the while I thought that you need to set the the group entity to Edges in order to have access to all the edge related options. So yeah, the Group Promote can be removed in this case, then just set the Group SOP to a Group Type of Points. :)
Hi, I've updated the file.
It now includes a way to create a group for each connected geometry, and only for those that are open.
I used the Connectivity SOP to create 'class' IDs for each connected primitive. Passed everything onto a Foreach by the 'class' attribute, then used the npointsgroup() to filter/switch out only the open geometries, where it then creates a unique group just for that using the Partition SOP.
H16.5.268 Indie - open_closed_tag.rar
  • Thanks 1
