neblina Posted November 22, 2017 Share Posted November 22, 2017 Hello everyone, here's the issue I'm encountering: From a set of points I'd like to delete all but one of them, and with a slider on the upper level be able to select which. I managed to to that, but if the slider has a value bigger than the total number of points I have a problem. So I thought about maybe clamping the slider value between 0 and the total number of points. I don't know if that is possible, but here's what I tried so far: Attribute Create node (posAttr) with a detail attribute (posAttr) with the following value: clamp(ch("../posParm"), 0, $NPT) After that a Delete node, Delete by Expression, Filter: $PT == detail("../posAttr", "posAttr", 0) I expected this would evaluate the value coming from the ch in the upper level and always clamp it between 0 and the number of points, but instead it does nothing. If the value goes past the number of points it still 'crashes'. If this is a completely wrong approach, how else could I accomplish this? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Parboil Posted November 22, 2017 Share Posted November 22, 2017 Hope this helps. I used a detail wrangle. int pt = chi("center_pt"); int upper = clamp(pt + chi("upper"), 0, npoints(0)); int lower = clamp(pt - chi("lower") -1, 0, npoints(0)); for (int i = lower; i< upper; i++){ removepoint(0, i); } Quote Link to comment Share on other sites More sharing options...
Noobini Posted November 22, 2017 Share Posted November 22, 2017 try this ? clamp.hipnc Quote Link to comment Share on other sites More sharing options...
neblina Posted November 23, 2017 Author Share Posted November 23, 2017 Yes, thank you. Somehow I figured this out yesterday, subtracting 1 from the $NPT does the trick. clamp(ch("../posParm"), 0, $NPT - 1) Just like your example, @Noobini. Quote Link to comment Share on other sites More sharing options...
