Justin K Posted December 6, 2017 Share Posted December 6, 2017 Hey, How do I randomize the scale on lines being fed into a for loop? Im used to using copy stamping for this but am trying to us the new methods. Ive attached a file. Im currently trying to drive the pscale attribute with either a wrangle or the new attribute expression sop. I have the loop set up correctly, and the meta data node referred to as iter1 is added as spare inputs for both. I cant put the rest together though. Thanks for the help! Chops_120617.hipnc Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 6, 2017 Share Posted December 6, 2017 so if you look at the detail syntax you have for the timeshift: detail(-1,"iteration",0) that is correct...but for some reason you didn't have this in your attribwrangle1, just use same syntax (and same for point2, if you do use it) and she'll be roight.... Quote Link to comment Share on other sites More sharing options...
