chishbak Posted December 9, 2017 Share Posted December 9, 2017 (edited) Hello Guys. I got stuck here in a middle of an project and i can't find a solution. My problem is : I have a grid of points , and an animated point running over the surface of the grid. My "running" point have an attribute that is transferd ( via attrib transfer SOP inside anSolver) to the grid points by an proximity radius. then I use the transfered attribute to isolate only the grid points that are tuched by the "running"point. But the @ptnum of the remaining points is changing. And i need the @ptnum to grow in the order detection ( @ptnum 1, 2, 3, 4, 5 etc) why is that happening to understand better I've attached the scene file ptnum_chaos.hip Edited December 9, 2017 by chishbak Quote Link to comment Share on other sites More sharing options...
3dome Posted December 9, 2017 Share Posted December 9, 2017 (edited) i dont understand your problem. the id's stay the same just fine. have a look at geometry spreadsheet. also both deletes work fine Edited December 9, 2017 by 3dome Quote Link to comment Share on other sites More sharing options...
chishbak Posted December 9, 2017 Author Share Posted December 9, 2017 My problem is that my points after delete, are changin their point id instead of being fix. If you show point numbers in viewport and then grab the timeslider, you can see for example der point 4 change it's position to point 5. But i guess I solve it with an custom attribute id. ( i@id = @ptnum in an wrangle right after solver) Quote Link to comment Share on other sites More sharing options...
3dome Posted December 10, 2017 Share Posted December 10, 2017 (edited) you already have an id attrib. you are creating it just before the solver don't care about the ptnum Houdini is displaying in the viewport. It does change of course that is why you have the id attrib. Just like with a particle sim where particles die and new ones get born they constantly change their ptnum in viewport but id (in spreadhsheet) stays the same and no, setting id to ptnum after the solver wont help at all Edited December 10, 2017 by 3dome Quote Link to comment Share on other sites More sharing options...
