Keyframe Maximum/Minimum Values
garf
You could do this in a CHOPnet.
Import your channel into CHOPs using Fetch or Object, depending on where the keyframes are, then use a Shuffle CHOP to split all the samples into separate channels. Then use a Math CHOP with Combine Channels set to "Maximum." The output channel will be the maximum found in the sampled range.
