Zdepth in point VOP
monomind
Is it possible to get zdepth within the point vop directly?
I currently calculate the distance from each point to the provided camera, but this seems to be very slow.
When rendering openGL, for instance, I can render out a zdepth in no time, so I blieve the information is already there, just not sure how to reach it through VOP
that  Zbuffer is a low res 12bit(?) z buffer calculated on the GPU. Nothing to do with a VOP.
That would be sufficient for me, if, somehow it's possible to get that information (per point) into VOP
Distance calculation per point is too costy to do per-frame, with too many points --- very slow.. Any ideas that would speed this process up would also benefit me highly!
