Create HDA using python
Korhon
This is the way I have done it in the past when creating a digital asset from a shelf tool:
# Create new digital using OBJ subnet as a base
temp_node = hou.node("/obj").createNode("subnet")
# Create new digital asset from temp node
hda_node = temp_node.createDigitalAsset(
  name = hda_name,
  hda_file_name = hdalib_directory + hda_name,
  description = "DESCRIPTION",
  min_num_inputs = 0,
  max_num_inputs = 0,
hda_node.setName("NAME")
# Get HDA definition
hda_def = hda_node.type().definition()
# Do whatever you need to do with the HDA here
# i.e. Creation, copying and organisation of children:
hou.moveNodesTo(tuple(other_premade_node), hda_node)
hda_node.layoutChildren()
# Update and save new HDA
hda_options = hda_def.options()
hda_options.setSaveInitialParmsAndContents(True)
hda_def.setOptions(hda_options)
hda_def.save(hda_def.libraryFilePath(), hda_node, hda_options)
  • Like 3
