Pop sprite Problem
asxp3
Hi Guys
I got a problem with pop sprite, I set a sprite rotation on my particle sim, I use rand(id) to make every particle rot differently but when the particle hit on the ground, the spriterot attribute keep going, so that it keep rotating on the ground when I assign a sprite texture, so is there a way to make the particle stop rotate once the particle hit on the ground?
thanks a lot for your help.
if you have collision information from your simulation you could do something like:
if (f@hitnum >= 1)
v@v = 0;
v@w = 0;
or if you  don't want it to completely stop from one frame to another you could do *= 0.75 instead.
might be a better way, but hard to say without a hipfile.
let me know if you need more specifics
