Calculate the distance between two point of different geometry
Hi, i've two geometry with a scatter node applied and i wont connect these point using an add node by color attribute create with a color node after scatter node.
so...
geo 1                      geo2
scatter1                   scatter2
color1                     color2
              merge
              add
Now i need to calculate the distance between the connected poit.
How can I do?
Thanks
Ok, i suppose that I have to connect my two streams in the first and second imput of attributewrangle, right?
Sorry my ignorance...
And furthermore, if i would to delete the longest line of a certain value, how can select these line? (line created with the connection of points)
Edited by Blackshadow
i forgot a piece of the message
Not on my computer right now but yes you have connect your 2 streams in the wrangle.
for the other question you could do an if statement and do something along this lines.
if(@dist > ch("threashold")){
    removepoint(0, @ptnum);
Just wanted to add a quick something to this: you can actually access another input's attributes without having to use the point function.
Appending opinput# before the attribute allows you to designate which input to access.
v@opinput1_P would access the second input's P attribute for instance. So you could actually get the distance with a single line :)
f@dist = distance(@P, v@opinput1_P);
  • Thanks 1
