H16 - Fractures falling into a flip tank - Explodes
Arun
I'm learning Houdini, and am trying to do a bullet-solver RBD Fracture, with glue constraint, falling into a FLIP tank. RBD PackedObject works fine with the constraint & collides perfectly with groundplane. But when I make them fall into a flip tank, the pieces explode at the frame where they touch the water. Feedback scale is set to 1.
Tried a default RBD sphere with Flip, and though I can control the Flip interaction with the "Physical" tab, the Sphere bounces still as if on hard ground.
Can somebody help me with this? [ Attached a sample fileRBDFlip001.hipnc]
I couldn't configure your scene, I think the glue portion is messing everything up. I threw away all the nodes except your original cube fracture. I recreated the scene using the shelf tools. I basically got the same result, everything explodes.
So the cube is too heavy.
I turn off the Compute Mass on the RBD Fracture object and set the weight of the cube directly to a mass of 10 (try lower values as well). This helps makes the cube lighter. I turned on Allow Fracture From Feedback under the Fracture tab of the Rigid Body solver. The fracture stays together until impact then it falls apart. No glue needed. I have animated the Feedback Scale from 2 to 0 over 12 frames. This is timed with the initial impact of the cube with the fluid. The feedback scale of 2 makes the surface of the fluid much like a groundplane. Then as it animates down to 0, over time, the fracture pieces that are skating on top slowly sink down into the fluid.
ap_RBDFlip001.hipnc
Edited by Atom
  • 3 years later...
