VEX: for i
fabsberry
Hello, I have a problem understanding "for i" in vex.
for (int i=0; i<npoints(0); i++) {
    float val = point(0, "value", i);
    float preval = point(0, "value", i-1);
    float calc = val+preval;
    setpointattrib(0, "value", i, calc, "set");
In the picture you can at first see my initial values.
Now i want to add the sum of the previous values to my current value .
I wrote the values i expected to get in red.
What is wrong with my "for i"?
You need to do it in different way, like this:
float accum = 0;
for (int i = 0; i < @numpt; i++)
    accum += val;
    setpointattrib(0, "value", i, accum);
Input doesn't changed during the code execution, we can't change and retrieve changed attribute values within same wrangle using geometry functions. If you set input point #1 @value from 1.0 to 2.0, when you query input point #1 value again using point() function, you still get unchanged value of 1.0. If you operate on points/vertices/primitives, you can use @-bindings, they are ordinary variables internally, and will work.
// Point Wrangle.
// Works.
@foo = 5.0;
@foo = @foo * 2.0;
// Doesn't work.
setpointattrib(0, "bar", @ptnum, 5.0);
setpointattrib(0, "bar", @ptnum, float(point(0, "bar", @ptnum)) * 2.0);
