Motion vector from animated sequence
BludArtworks
Hello !
I try to create motion vector from 2D animation sequence for using in game engine (unreal). I try first to render the result of volume optical flow using volume slice and gamebaker but there no files when I press render and no error message neither.
What I'm doing wrong ?
Thanks a lots :)
motionvector.zipFetching info...
Edited by BludArtworks
Ok I made it !
The big mistake was I didnt converted the volume slice mesh into polygons.
I used the "sop simple baker" from game dev tools.
I normalised the vector using the attribute promote to get the min and max and put it in a pointvop.
Things to fix : right now I just add arbitrary number to my normalised output to get a perfect ".5" value on "blank" space. Didnt figured a way to do it procedurally.
motionvector_02.zip
  • Like 2
