Entagma Packing the torus tutorial
mossawi
Hi guys,
I just finished this Entagma tutorial which was great, and am having 1 issue: http://www.entagma.com/packing-the-torus
Packing a torus or a cube is working perfect for me, but when I go ahead and import a shape from illustrator, extrude it, and use it as my geometry, it works up to the point where i start to boolean my spheres using the "Cookie" node. Any suggestions what Im doing wrong?
Please let me know if I should attach my scene if this is confusing.
Thanks and all the best.
Attaching your scene is usually helpful, if you're allowed to do so.
Most of the issues regarding use of the Cookie/Boolean(Updated version) node is related to the inputs you provide.
If you provide contiguous surfaces (no holes) it usually works fine.
Here is a thread you may find helpful: Boolean
