Loading Errors
mossawi
Yeah the different version will certainly cause those types of errors. As you update Houdini versions over time, you will nodes and their parameters change. These list the missing links being described in the file and those available in your active Houdini session. If you save the scene file in your current version again and then reopen the errors should go away... The one exception is that if an HDA was built in another version of Houdini.
