rosanky Posted February 14, 2018 Share Posted February 14, 2018 Ive made this ring and I'm just trying to figure out how to add noise to the few points at the start of the ring as well. If you take a look at my example you'll see there's a section on the ring that doesn't animate. Any help would be much appreciated. Oh! PS: I'm a newb so Please bare that in mind. -Ryan VFX_LightningLoop.hip Quote Link to comment Share on other sites More sharing options...
Sepu Posted February 14, 2018 Share Posted February 14, 2018 You do not need the for each there. You could use Chops but isn't need it, you can just use a noise in a VOP Sop. Wrangles and VOPs run through all the points, you could change this to prims, vertex, etc depending of your needs. Anyway here are 2 options one using CHops and the other one using VOPs VFX_LightningLoop_fix.hipnc Quote Link to comment Share on other sites More sharing options...
rosanky Posted February 14, 2018 Author Share Posted February 14, 2018 Thank you so much! Quote Link to comment Share on other sites More sharing options...
