Syrena Posted February 18, 2018 Share Posted February 18, 2018 Hello! I'm trying to get velocity from a sopgeo (simple trail velocity from geo node), into a vectorfield to add custom velocity to a fluid sim. I followed the examples in the fluid solvers masterclass, but I can't get this to work. There's no velocity at all from the sopgeo that influences the vectorfield. Also, I'm not sure if I'm suppose to resize the vectorfield to the same size of the fluidsim which 5x5x5. Been playing with this for a while now and I need help on the basics of how to get this to work. Quote Link to comment Share on other sites More sharing options...
tamagochy Posted February 19, 2018 Share Posted February 19, 2018 If you want get help you should give us the file. For now it's impossible to help you looking to the picture... Quote Link to comment Share on other sites More sharing options...
Syrena Posted February 19, 2018 Author Share Posted February 19, 2018 5 hours ago, tamagochy said: If you want get help you should give us the file. For now it's impossible to help you looking to the picture... Hello Tamagochy! Okay here's the file =) vectorfield_fluidsim.hipnc Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted February 19, 2018 Share Posted February 19, 2018 (edited) Here is the correction for the file! The problem was that you were using copy mode in the gas calculate, you need to add this pump to your velocity, but also you need to take care with the substeps, that's why I activated also a linear scale multiply mode for the pump to then scale all by the scene FPS. I recommend you also that's is better to use ad-hoc fields (temporal data), it has memory advantages just cleaning that field but also the creation time when dealing with heavy data, for this try to use a gas match field instead. Cheers, Alejandro vectorfield_fluidsim.hipnc Edited February 19, 2018 by Pazuzu Quote Link to comment Share on other sites More sharing options...
Syrena Posted February 20, 2018 Author Share Posted February 20, 2018 Wow! Thanks so much for the corrections and informations! I'll have to study all this more... Quote Link to comment Share on other sites More sharing options...
