Jamshid63 Posted February 26, 2018 Share Posted February 26, 2018 HI , I was rendering Ocean using Ocean spectrum and surface, nothing advanced , but I'm getting this weird issue. When I render out in 540p, everything is as it should be but when I render it out in 720p, some parts of it is missing and when I render it out in 1080p, even more parts are missing. So i decided to change the camera angle just for testing, and there it is, everything is perfect, no cutting the edge or anything been noticed, even in FUll HD. I have attached all 4. (in the top view render you can notice the shape of my Ocean, Actually Those are only area i want to render, so ignore the shape ). Please Help me out. Quote Link to comment Share on other sites More sharing options...
nemesis9309 Posted February 26, 2018 Share Posted February 26, 2018 Are you culling the spectrum based on camera? I dont know if thats it but if you are culling it then try not to do it and see if it helps Quote Link to comment Share on other sites More sharing options...
Jamshid63 Posted February 27, 2018 Author Share Posted February 27, 2018 16 hours ago, nemesis9309 said: Are you culling the spectrum based on camera? I dont know if thats it but if you are culling it then try not to do it and see if it helps HI, I havent changed the camera or culling...its just a basic ocean surface and its interior. But i do have ocean foam which is based on camera, which i dont think thats the cause for this weird issue. Quote Link to comment Share on other sites More sharing options...
