RENDER Problem Ocean Spectrum
Jamshid63
HI ,
I was rendering Ocean using Ocean spectrum and surface, nothing advanced , but I'm getting this weird issue.
When I render out in 540p, everything is as it should be but when I render it out in 720p, some parts of it is missing and when I render it out in 1080p, even more parts are missing.
So i decided to change the camera angle just for testing, and there it is, everything is perfect, no cutting the edge or anything been noticed, even in FUll HD.
I have attached all 4.  (in the top view render you can notice the shape of my Ocean, Actually Those are only area i want to render, so ignore the shape ).
Please Help me out.
16 hours ago, nemesis9309 said:
Are you culling the spectrum based on camera? I dont know if thats it but if you are culling it then try not to do it and see if it helps
HI,
I havent changed the camera or culling...its just a basic ocean surface and its interior. But i do have ocean foam which is based on camera, which i dont think thats the cause for this weird issue.
