Fracturing/art direction question
thejamesporter
Hey guys,
I've a question about setting up geo for a simulation. I want the tube to break away into four large pieces, which would break up further.
I've 'shattered' this tube with a boolean sop, so I get the straight pieces I want.
5a968075adabf_ScreenShot2018-02-28at11_09_53PM.thumb.png.742c2b90f11f8905a526a644e1656a1f.png
I want to fracture these pieces four shattered pieces further. What's the best way to achieve this?
OR
Is it better to fracture the entire tube in one hit and use a constraint to create the larger straight pieces?
I'd appreciate some ideas.
James
You can add a connectivity sop and for example put them through a for each loop and scatter points and add a voronoi. Or you can keep using the boolean with a copy to pts as well.
Take a look at this masterclasses too.
